It is currently Sat Jul 19, 2025 4:00 pm
PostPosted: Fri Nov 17, 2006 6:28 am
For some time I have been looking at the various vacuum options to use for glueing/guitar holder, etc. Just wondering what all think about the compressor vacuum valve that LMI sells as opposed to using a vacuum pump. Any advangages/disadvantages. Also, how does the old style guitar holder that LMI has compare to the new style? LMI is clearancing out the old model for quite a bit less that the new model. THanks for any help
Tom Harbin
PostPosted: Fri Nov 17, 2006 7:37 am
I have the LMII vacuum pump. It does the job well but is constantly
running. If I had to do it over, (and I will within the year) I would build
one of these:
http://www.joewoodworker.com/veneering/partsoverview.htm
Relatively inexpensive, and they would be excellent for what we do.
However, I do recommend LMII's valve that reads PSI and the vacuum
release.
Hopefully, someone will chime in about the compressor vacuum valve
from LMII.
Peace Out,
Simon
PostPosted: Fri Nov 17, 2006 8:36 am
Thanks Simon: Anyone else out there that has done a Joe Woodworker vacuum kit, please let me know which type and how you like it. tom
PostPosted: Fri Nov 17, 2006 8:42 am
Hi Tom,
I've used the little venturi pump from LMI for the last 6 years or so ... works well. I've switched over to a continuos vacuum pump system which I like much more. I use the refurbished Thomas pump from joewoodworker.com. Great little unit:
I've donated my venturi pump to OLF ... Lance is going to put it up for auction soon, I think.
Best,
Jim
James Warwick
J. Warwick Guitars, LLC
PostPosted: Fri Nov 17, 2006 9:53 am
[QUOTE=Tom Harbin] Thanks Simon: Anyone else out there that has done a Joe Woodworker vacuum kit, please let me know which type and how you like it. tom[/QUOTE]
I have the Joe Woodworker set up with the GAST pump. It works flawlessly.
PostPosted: Fri Nov 17, 2006 10:16 am
Is the JoeWoodworker setup superior to the LMII vacuum set up (not the venturi that runs off of a compressor)? It's a little more expensive with the JW setup, but not by much.
PostPosted: Fri Nov 17, 2006 1:01 pm
When I was making drums, I used a vacuum setup for veneering. I used
this one: http://www.vacupress.com/products2.htm#compact100
It is $336 and comes with a bag. They'll take the cost of the bag off for
you. The only issue is that it doesn't have a regulator, which means it will
crush most anything unless reinforced. It was a flawless setup though
and didn't take any time at all to get running. You can add the regulator.
PostPosted: Fri Nov 17, 2006 3:38 pm
i have the joewoodworker venturi and reservoir system as well as a commercial venturi powered workholder/routing clamp. the joewoodworker system is cheaper than the lmi venturi and works very well.
i used a vacuum pump for powering routing clamps, etc., for years but find the venturi system better.
any vacuum system is improved out of sight with a reservoir.
PostPosted: Fri Nov 17, 2006 4:17 pm
Last Name: Garrish
I have a venturi from Quality Vakuum and it works pretty well. Using the regulator on the venturi, I can 'dial in' the amount of vacuum I want depending on the leakage in a system. With something like a bag you can always seal it off once you pull the vacuum you want, if you're running fragile parts or something. I might end up putting a tank inline with it but at the moment that seems unnecessary.
Bob Garrish
PostPosted: Mon Nov 20, 2006 12:52 am
Thanks for all the replies. I've still got some homework to do. thanks, Tom H
PostPosted: Mon Nov 20, 2006 3:58 am
I have been using the vacuum pump system as per joewoodworker's plans for over 3 years with perfect results.
I bought a used Gast pump on eBay before he started selling them on his site.
It is much quieter than a venturi system, especially when you use a large auxillary tank to reduce the pump cycling.
PostPosted: Mon Nov 20, 2006 4:10 am
Shawn, which style/model of Gast pump did you get, rotary vane or diaphragm? Something else? Thanks for the review, I'm seriously looking into making one. Noise is a big issue for me, which is why I suspect I'd like the JW system over the continuous run pump on the LMI setup.
PostPosted: Mon Nov 20, 2006 4:34 am
The continuous run actually isn't that loud. The one in the LMI pic looks
exactly like what I had before selling it. Not loud at all. They aren't like
air compressors, or at least what I had wasn't.
PostPosted: Mon Nov 20, 2006 4:37 am
I figured they wouldn't be all that loud, I remember Harry Fleishman had two or three old fridge motors as vacuum pumps in his shop and it wasn't that bad. Still, if more silence can be had for a comparable price...
